-   -   X Dimension on 24x7 (https://www.offshoreonly.com/forums/drives-lower-units/288585-x-dimension-24x7.html)
smiklos@sunprint 12-10-2012 05:59 AM
Hang a line down centerline of transom or standoff box to determine actual height before cutting.
Steve
scarab63 12-10-2012 02:54 PM
Originally Posted by lil red (Post 3828674)
yes it is, but when measuring to cut the x, you need to measure straight up the transom perpendicular to the bottom to get the actual x dimesnsion. taking the angle of the transom out of the equation, measuring parallel with the transom would give you a longer measurement but the hole still in the same place. Just making sure were all talking the same measurement. I'll have to check how far below the pad the propshaft is.
Prop shaft is about -3"
tomas_wallin 12-10-2012 03:08 PM
If you're at 3" with the prop shaft parallell to the bottom (not the pad) you're at an X a bit higher than 17".
Unlimited jd 12-10-2012 04:29 PM
Yep my memory must be shot! Sorry guys
scarab63 12-10-2012 05:51 PM
If I remember I was waffling between 17 & 18 so we split the difference....
Also my -3" is by eye......no straight lines or anything so easily +/-
scarab63 12-10-2012 05:53 PM
It happens!:lolhit:
Boatally Insane 12-16-2012 07:55 PM
THANKS for all the replies. !
Finally cut it today..
.... Went with 18.5" :drink:
http://i130.photobucket.com/albums/p...ps09aee32b.jpg
tomas_wallin 12-17-2012 04:02 AM
Will you do the bottom as well?
Boatally Insane 12-17-2012 07:08 AM
I already had it flipped and shapened the edges of the strakes and the pad.
No hook in the hull at all... :)
http://www.offshoreonly.com/forums/e...r-project.html
http://i130.photobucket.com/albums/p...r/P4280045.jpg
26 Spyder 09-14-2014 09:53 AM
Did this ever hit the water? Results?
