-   -   trs vs konrad x dimension (https://www.offshoreonly.com/forums/drives-lower-units/288986-trs-vs-konrad-x-dimension.html)
performance334 12-17-2012 05:27 PM
so i pulled the motors, drives and trans out of the old 12 meter a few weeks ago to have trans rebuilt, and new valve springs put in the engine's.... my question is what is the difference in x dimension between the trs that was standard on the boat and the konrads that are on it now, i kno konrad sells spacers and im wondering if i put the lower unit down a little bit if the drives will hold up better?!?!? thoughts comments thanks!!! :cartman:
MILD THUNDER 12-17-2012 05:31 PM
Not sure what you mean ''hold up better''? Do you mean hook up better like for planing?
On a old 12 meter, I'd think the higher drive height with props turning inwards would be the way to go. What speed and engine RPM are you seeing now?
performance334 12-17-2012 05:36 PM
myself and previous owners have had problems with the lower units letting go....the boats performance is perfect i dont want to change a thing.. just looking to get a lill more life out of the drives if at all possible, would putting the spacers on and moving prop down help with this at all??
kidapache 12-17-2012 10:50 PM
I have new 2" spacers for konrad $1,000 for both and one gimble $1,500
picklenjim 12-18-2012 01:44 AM
X dimension on the transom would still be the same. You need to check how far the prop shaft is below the bottom of the boat. Hold a straight edge against the bottom of the boat extending out the back and trim the drive to where the prop shaft is parallel to the straight edge. Then measure the distance between the straight edge and the prop shaft. If I remember correctly a Konrad is 1.6" shorter than a TRS. As for the best distance to run the prop shaft below the bottom on that boat I have no clue. Hopefully someone else can chime in with that figure. Are you running cleavers?
performance334 12-18-2012 12:15 PM
ok got you ill have to check that measurement once she is back together... but just as a general question do you think its better for drive life to be lower in the water?? i think i have herd it is slower, but that is not really my concern....
thanks again for any input!!!
MILD THUNDER 12-18-2012 12:27 PM
Propshafts 1" below the bottom on my old 38 with speed master iv's. 180 hours on them with between 650-800hp. Still tight and no fuzz on the magnets. My guess is your props are quite a bit deeper than mine with your Konrad setup. In general, deeper would be easier on them if you boat in rough water
How much hp you putting thru them? How many hours you getting out of them?
Rookie 12-18-2012 01:06 PM
You are not surfacing the Konrads?
I had been contemplating the Konrad swap but yet have had any issues over 3 years with my TRS and 600HP. I will see this summer when I add superchargers.
