Alpha gen 2 to bravo 1 conversion >
Old 12-20-2012 | 10:48 AM
Default Alpha gen 2 to bravo 1 conversion
I have an alpha 1 gen 2 that am not happy with it I know it's a time bomb with a 454. What do I need to buy to swap to a bravo 1 drive?
kakarot is offline
Old 12-20-2012 | 11:50 AM
Wally's Avatar
Were doomed!
the inner and outer transome plate/gimble assembly along with the trim cyl's and the drive itself....though i have heard the trim cylinders will work from one to the other but not sure on that one. you can re-use the hyd pump...oh and a new coupler while its all apart....thats about it.
-Wally
Wally is offline
Old 12-20-2012 | 02:05 PM
It's even easier with the gen 2, just swap the helmet so that Bravo will fit. Everything will will work. You will how ever have a gap between the pin for the ram's.
Two options run it with the gap, or put in an aluminum filler. I've seen both done.
Kings11 is offline
Old 12-20-2012 | 02:51 PM
Thanks a lot guys will I have to pull the motor out?
kakarot is offline
Old 12-20-2012 | 03:10 PM
You might want to add one of those thing-a-ma-jiggies that sucks up water to cool the engine.
floatingphil is offline
Old 12-20-2012 | 03:46 PM
masi242's Avatar
Yes you need a new water pick up belt driven and another 3k minimum, what kind of boat do you have and it`s weight. I have a 454/alpha in my Formula 242LS and it`s fine you just take it easy.
masi242 is offline
Old 12-20-2012 | 03:55 PM
It's a Jaws 24 I just been told that the alpha won't hold much with the 454
kakarot is offline
Old 12-20-2012 | 05:26 PM
check mercury,I am pretty sure that they still make a set of hardened upper gears for the alpha's and they do work,they are supplied by mercury specifically for that set up with a 454.
activator40 is offline
Old 12-20-2012 | 06:05 PM
The cheapest option would be to buy a complete boat with bravo running gear off craigslist or the like..... Do a complete swap alpha to bravo & bravo to alpha....then re sell the boat.
More work, less $
All the parts will be exactly where ya need em.
Will have to plug a couple holes on the donor boat when going bravo to alpha.
scarab63 is offline
Old 12-20-2012 | 07:46 PM
I guess I would have to check with mercury, is there any speed difference from just swapping the drives from alpha to bravo?
kakarot is offline
