whats going on
Old 02-10-2013 | 11:59 AM
Question whats going on
need advice as where to look for this problem, when cruising down the lake an start to air the boat out bringing the nose up with trim, the outdrive or motor will freak out its hard to pinpoint the problem and describe it. its almost like a short or something its not porpoiseiong or blowing out it just shutters or shorts. its a bravo one the problem occurs when trimming up at hard trottle. thanks for any input just dont know where to begin looking
the hite guy is offline
Old 02-10-2013 | 12:19 PM
1 MAIDEN AMERICA's Avatar
Are you trimming too high?
There's normal trim and trailer position.
Too high would cause U Joint vibes and an ugly failure.
1 MAIDEN AMERICA is offline
Old 02-10-2013 | 03:08 PM
it is possible the trim pump is going away, either the motor or the valving in it. when you are accelerating hard and trimming up it requires the most pressure to move the drive and so it is loading the pump more than any other time.
compedgemarine is offline
Old 02-10-2013 | 03:11 PM
Tinkerer's Avatar
You could have a bad U joint and it is vibrating when You trim up.
Try in gear with the drive all the way down - turn the drive all the way one way. Is it vibrating the drive or making any strange noise?
Tinkerer is offline
Old 02-11-2013 | 02:14 PM
What does it mean to short? Does the motor shakes or the prop grabs funny? See if you lower the trim the problem goes away. Check to see if the trailing edge of the prop is cupped. NON CUPPED PROPS SLIP AND RE GRAB. Even cupped props chatter or slip if over trimmed.
good luck Buddy
Amarket Owner is offline
