-   -   shift cable? (https://www.offshoreonly.com/forums/drives-lower-units/292113-shift-cable.html)
HOFFMAN514 02-25-2013 09:31 PM
shift cable?
Hello everyone, I posted this in the Chris craft section but didn't get anything so thought I'd throw it up here too. I have an 88 Chris craft scorpion 210 with the 260 HP mid engine 350 and alpha 1 out drive. Last summer the shift cable got hooked by a cooler and now when you go past 3/4 throttle it goes I to neutral. Once you pull it back it goes back in gear. Could this just be a cable issue or did something else go wrong? I also have a crack in the impeller hose near the transom and the trim switches do not work so my plan was to just replace/service everything at once (gimble bearing, trim switches, bellows, shift cable, hose, etc.) But wanted to be sure a cable will fix the issue at hand first. Also I have never done this before so any advice would be greatly appreciated and also are there any special tools needed to do this job. Btw I am an automotive master tech and have many tools and a shop but work on things with wheels so this is a bit different than what I'm used to. Thanks again for any help.
johnnyboatman 02-26-2013 09:10 PM
yes check the adjustment or the lever that the cables go to somewhere somethings out of sync. sometime they can be tricky to adjust.
