Bravo Big shaft conversion >
Old 02-27-2013 | 11:07 AM
Default Bravo Big shaft conversion
Hello, Can CMI's captin's call/silent choice still be used with the 1 1/4 big shaft conversions on a bravo one drive? I have not been able to find any information on it and I thinking that it can not be. Thanks in advance.
Blown96w is offline
Old 02-27-2013 | 01:38 PM
Knot 4 Me's Avatar
Any Captain's Call/Silent Choice setup I've ever seen runs an exhaust tube. Got a buddy with a 33 Outlaw with 500 EFI's, Silent Choice, and XZ's which have the bigger prop shafts.
Knot 4 Me is offline
Old 02-27-2013 | 07:45 PM
Exhaust tube? can you expalin a little more
Blown96w is offline
Old 02-27-2013 | 08:28 PM
He means the exhaust bellows I think??. Some old school guys call them tubes or boots. When you switch the silent choice on it'll go down the y pipe through the transom assembly and out the exhaust bellow. I don't personally have any experience with the big prop shafts but I see 0 reason why it wouldn't work. You can eliminate the bellow and even be fine plenty of them have been ripped as long as the flappers in the y pipes are good no water is coming back up. It'll just dump the exhaust under water without the bellow directing water into the prop
mickeymcclgn is offline
Old 02-27-2013 | 09:41 PM
Yes it will still work. Just use the boot instead of bellows, it helps relieve the pressure.
jray1010 is offline
Old 02-27-2013 | 09:43 PM
Sorry I ment tube not boot. Its part # 78458a1
jray1010 is offline
Old 02-28-2013 | 06:47 AM
Yes it would still work the exhaust exit holes in the 1 1/4 prop shaft carrier are about 1/2 the size of the stock bravo carrier, as stated above remove the exhaust bellows and install the boot style so you don't restrict the exhaust.
waconda is offline
Old 02-28-2013 | 08:16 AM
Knot 4 Me's Avatar
http://www.wholesalemarine.com/p/SIE...by+Sierra.html
If your boat has a bellows instead of a tube, you can always remove the bellows and cut it short so it does not attach to the drive.
Old 02-28-2013 | 08:25 AM
Thank you all for the help, Ill be pulling the bellows and replacing it with tubes as soon as the weather breaks.
Blown96w is offline
