To shower, or not to shower....
I had 454 420's, with a few "extras".....making combined flywheel at 1009hp.
Now, I am dropping in new Merlin 540's with B&M non chilled 250's that have combined flywheel at 1498.... These are gonna sit in front of Borg red tags and refreshed trs's. As you know, no exhaust through trs's, so lower drive temp there. I am hearing varied opinion over drive shower. A) None available B) none needed My x is remaining stock till I kill them, but what is the real story here? Also, what are the two two-prong sensors for? One is center top, on is port side toward rear.... |
Both A & B are correct
No shower on my boat. This has been debated a lot and I'm not convinced that they actually lower overall oil temp. I'm also not convinced that our drives are running high and dry. I know they get chalky deposits on them but it's what's inside that matters.
Originally Posted by commandersander
(Post 3896843)
Would it not be more economical to sell the X's when they're still alive? |
I've been told that there not needed, but with the more power I can't see it hurting anything. I've also never looked for them either for TRS's. I know on another site someone put a temp sensor where the check level plug is and the temp only dropped 1-2 degrees with the showers, those were Bravos too I believe.
I would say if your going to be running the boat long and hard for extended periods then try to build something for them, if not then no point I guess. The TRS's also store more gear oil then Bravos so that's something to think about too. With the drives hanging lower in the water the oil prob doesn't get as warm as oil in a Bravo. |
On a TRS, the coupler (upper to lower shafts) also performs as an oil pump. With the lower gear case always submerged and the oil circulating, there is no need for a drive shower.
Bravo drives do not circulate oil. Some have seen a benefit in this application. I'd be more concerned about the transmissions handling the power increase. |
Thanks for the replies fellers.....
I think I'll just leave em alone....and hope for the best with the trans. Sure would be nice if there were a two-speed:eekdrop: |
Originally Posted by Cole2534
(Post 3897160)
What's the theory here?
Biggus is right !!! worry about the transmissions first....Once you start pumping power to them they may not last very long ..... Good luck.
Jim |
What can I do to extend their life?
You can add a bigger trans fluid cooler and change fluid often. Heat kills any kind of oil, so keeping it cool helps a lot.
Originally Posted by Plowtownmissile
(Post 3897290)
He's talking about his X-dimension.
In order to make them last longer I am pretty sure that they will have to be taken out ,torn down and rebuilt with stronger parts.clutch disks are card board if i remember correctly and needs to be replaced with bronze ----- been a long time can't remember if any other parts need replaced: In any event you are probably looking at some hefty bucks to rebuild let alone the labor...... Smitty makes a good point about the fluid !!Good luck.....
Jim |
Can I use an oil cooler like already mounted on the rear of the motor or am I better using and air to air cooler with a small fan? I have tons of house power (6 blue top optimas) and alts are 195a each...so drain is not a concern....just want it to last as long as possible.
As far as discs, I can swap that on my own just before I drop the Merlins in....but pump and converter should hold up? I have no issue matching r's on re-entry.... |
If it were me ,I would not use that set up with the fans. Never herd of anybody using fans in a marine application ...... I don't think it would work very well ---You need seperate coolers for each transmission and water is the only way to go ..If I remember correctly the old TRS 280 trasmissions had a built-in cooler and had to be winterized seperate from everything else in the engine comp. Just an idea !!
As far as rebuilding the trannies with new clutches -I dont think I wouuld tackle that job myself------If you screw something up you have a major problem on your hands.Call these guys:Kalamazoo Marine Gear - 2706 Portage Dr. Kalamazoo Mich 49001 Phone 616 -345-0629 Ask for Mark Gernsback---Dont know ,he might be retired now but if they are still there any of the guys can help. They remanufacture everything when it come to BW transmissions... Good luck again Jim |
Only use water cooled coolers !!!!! Lake water is only used one pass thru and an endless supply of it. The stock coolers are not enough. Use the stock one and plumb in an additional cooler after the stock one.
Sorry....meant air to water with fans.....like an after cooler...
I just remembered where I got my coolers from....Sen-dure. They have any size you could want.
http://sen-dure.com/ |
Trs drive showers
I have made trs showers similar to the bravo ones. 2 are on a friends boat.he can look over the back and says they work great.if your interested.
| All times are GMT -5. The time now is 01:07 AM. |
