Custom drive shifts very stiff
So my bravo one has Xr upper gears, a custom tower,and billet top cap. I just bought the boat, and noticed it shifts into gear very stiff. Shifter is hard to push forward and reverse. Any thoughts as to what would cause this?
are you shifting it with out the engine running?? if so dont do that unless you have to..always try to shift running.
a lot of possibilities,gears are not timed correctly in upper gearcase,control cables dragging,lower shift cables dragging,shift link cavity has water in it causing rust where the detent ball rides on shift link,what year is set up?
