bravo lower
Old 04-17-2013 | 08:38 AM
Fenderjack's Avatar
Pirate of the Chesapeake
Default bravo lower
Is the bravo 1 standard lower gears the same as the xr lower gears other than a bigger prop shaft is the housing different ?????Need info I know the tops are!JOHN SR
Fenderjack is offline
Old 04-17-2013 | 11:23 AM
Mr Gadgets's Avatar
Charter Member #601
the driven gear has a larger bore than the standard B1
Mr Gadgets is offline
Old 04-17-2013 | 11:33 AM
Fenderjack's Avatar
When running some power 650 hp would the standard bravo hold up or could that gear and upper shaft be changed????Have a chance to buy some lowers and need a place to start we are running 650/700 hp.Just don't have the money now for the high doller stuff. JOHN SR
Old 04-17-2013 | 12:14 PM
Fenderjack's Avatar
ttt
Old 04-17-2013 | 07:28 PM
Been running a XR upr with bravo 1 lower for years with 650 - 800+ HP. Never broke either. Run it stupid and it wont last a day. Use your head and it will last a long time.
michigan troll is offline
Old 04-18-2013 | 07:56 PM
For a point of reference, what's your boat weigh?
Cole2534 is offline
Old 04-19-2013 | 09:21 AM
blue thunder's Avatar
I run about that for hp on a twin engine boat, 7500lbs. I have trouble twisting propshafts and vertical shafts but gears no problem. I keep on close eye on the splines and if I wing it (bad throttle work) can end up having to swap out a shaft.
blue thunder is offline
Old 04-19-2013 | 06:44 PM
28' AT single with fuel and people approx 5700lbs.
Running a 5 blade Maxximus.
I hear all the time people breaking drives.
Run it like you know what your doing and it can live.
Drive it like a ars with throttle down and no idea of to back off or punch off the line and it wont last an hour.
