How much trim is too much on a SSM II TRS >
Old 05-14-2013 | 10:52 PM
phughes69's Avatar
Default How much trim is too much on a SSM II TRS
Last year I was running 3 blades on my SSM IIs and turning out. This year I am trying a set of 4 blades to try to get the boat to plane a little easier. The engines at twin turbo 454's making (est) 600 HP. Last year when I would trim the drives up it felt like the boat kept going faster. What would people consider too much trim knowing that it is a TRS outdrive (input shaft support bearing in the tailstock vs bravo style gimbel bearing).
phughes69 is offline
Old 05-16-2013 | 10:15 AM
Where did you find the 4 blades?
I don't think where the tailstock bearing is makes any difference because it is all being transmitted to the transom any way.
Wannabe
wannabe is offline
Old 05-16-2013 | 10:46 AM
phughes69's Avatar
Found them on CL last year. Ill have to cut my anticavitation plates to give them room and I'll have to use a thinnner lock nut on the propshaft but otherwise they fit. I'm hoping they will give me the results I'm looking for
Old 05-21-2013 | 11:37 AM
i run a lot of trim when legging her ou +3-4
wannabe is offline
