-   -   Bravo 1 failure 454 mag procharger (https://www.offshoreonly.com/forums/drives-lower-units/298342-bravo-1-failure-454-mag-procharger.html)
Plus Man 06-17-2013 11:52 PM
I have a 27 foot victory advantage has a 454 with a ProCharger 5 pounds of boost was out yesterday running wide open and outdrivre came out of water .Wrecked the top gear and noticed a crack in the case at the base of the tower.Is the case toast.I think im around 559hp .am I over hp for the Bravo 1 can The case be fixed .or scrap it. I can buy a used Bravo 1 gear ratio is 1.36 mine was a 1.5 .or spend another 1500 for a used Bravo x with a 1.6 ratio thx
Fenderjack 06-18-2013 12:56 AM
When that happens you need to pull back on the stick. If the case is cracked your better off buying a new one rather then having it fixed. The 1.3 gear is going to be harder on the parts in the drive vs the 1.5
John jr
Griff 06-18-2013 01:17 AM
Cracked case = scrap metal
ACrooks69 06-18-2013 07:56 AM
Depending on the year (sn of the bravo) I would get the std drive and have Dick blueprint it with a steel tower. He also can also swap in a steel retainer instead of the aluminum one that holds the u-joint assembly in. The X in going to have the same upper gears as the std (sn dependent), but it already has the steel tower. I had him go through my drive and set it up to hold my blower motor and it cost less than the difference in the Std vs X you listed. It will add acoule weeks to your downtime, but man did my drive shift night and day different when he set it up.
Mr Gadgets 06-20-2013 06:10 AM
Depending on the damage to the case, it may be fixable. Can you supply some pics of the area, as well as the snout and wear pad areas?
Dick
