-   -   bravo 1 parts (https://www.offshoreonly.com/forums/drives-lower-units/298801-bravo-1-parts.html)
cp5899 06-29-2013 09:00 AM
The kits that you listed, is that considered the x gears?
Mbam 06-29-2013 09:13 AM
Kind-of-not-really
All the new style gears, including the X have the thicker floor. The actual X gear is the same gear but the input spline on the U joint is bigger. But people do call these the X gears even though they are not. Did I explain it OK?
cp5899 06-29-2013 09:25 AM
Yes. I understand. The larger spline would obviously require a new input shaft. Are there any other parts that can be added to help my bravo 1 live a longer life? Do the thicker floored gears make that big of a difference? I'm not shearing teeth off, but cracking the floors out of forward gear.
Mbam 06-29-2013 09:30 AM
They will pretty much eliminate cracking the floor out. Your problem is the reason Mercury came out with them.
indysupra 07-04-2013 08:12 PM
Anyone have a picture of a gear with the floor knocked out of it?
badbug 07-08-2013 12:57 PM
why do u need a picture when u said in the first of the thread u had one with the floor knocked out??????????
indysupra 07-08-2013 01:57 PM
Because. I wanted to compare. The damage to the gear is not a crack its material from the washer that broke. I was thinking about replacing the bearing and washer and swapping it to the bottom gear.
cp5899 07-09-2013 02:51 PM
The first time mine broke it busted the bearing. I put a new bearing in and 5 minutes of run time later it's busted the gear floor out. Here a picture of the bottom cracked out. I'm in the middle of putting thick floor gears in my drive and hope that works better.
http://i1126.photobucket.com/albums/...7730724D29.jpg
