IMCO Lower with oiling modification? >
Old 07-10-2013 | 02:23 PM
Default IMCO Lower with oiling modification?
While service my drives we noticed this modification any ever seen this before? Should I leave it? Seems I cant post pictures. The best I can describe it is a port from the oiling channel into the vertical shaft area.
Steve
smiklos@sunprint is offline
Old 07-11-2013 | 05:56 AM
Mr Gadgets's Avatar
Charter Member #601
Steve, if you want to, email me the pictures so I can see what you are talking about..
Dick
Mr Gadgets is offline
Old 07-11-2013 | 03:44 PM
The very early Bravo drives did not have the oil gally feeding the pinion bearings. They did promote some oil flow from bottom to top via an oil port up at
the upper end of the lower unit in the area just below the small bearing cup bore in the driveshaft cavity. When I was working at Imco a long time ago we did
mods. just as you describe.
Hpoe this helps Mac
onedownonetogo is offline
