Is the input shaft on a TRS/ Borg Warner different than a TRS/ Merc trans >
Old 07-11-2013 | 09:45 AM
phughes69's Avatar
Default Is the input shaft on a TRS/ Borg Warner different than a TRS/ Merc trans
Is the input shaft on a TRS/ Borg Warner different than a TRS/ Merc trans. Are they the same spline count and length? I check BAM's site and did not see a different part number, but I wanted to ask and make sure.
phughes69 is offline
Old 07-11-2013 | 09:47 AM
Yes. They are different. The B/W is a male splined shaft, Merc trans is a female.
MILD THUNDER is offline
Old 07-11-2013 | 01:37 PM
you mean the yoke for the drive correct? the input for the trans are both male but the BW trans is larger.
ray pampena is offline
Old 07-16-2013 | 10:54 AM
rws's Avatar
rws
Pat you can change the the MercII input shafts with the ones off of your #2's i sold you a borg warner input shaft a few years ago.
rws is offline
Old 07-25-2013 | 11:25 PM
NOPE! As Thunder said, The B/W is male splined and the Merc Trans is female splined.
picklenjim is offline
