Bravo 1 issue
So I'm heading out on then water from my house and I see a go fast sitting with the hatch up. I make my way over to him, he lost a motor (the one with his steering) on his 38 ft Sonic. I offer to tow him in and proceed running about 1100 rpm for about 1/2 hour. After I cut him loose I went to put mine on forward gear and nothing! The past 2 times out I had to push the the shifter hard to get in gear. The shifter moves smoothley. Reverse if fine. I got my boat home and checked the gear fluid and was about half a quart low. Turns out the shifter cable let loose on the outdrive (pulled away from the threaded end).
It looks like an
up hill battle to replace with out pulling the motor. Any ideas????????
It looks like an
It looks like an
It looks like an
Thanks smokin gun. Got it done. Used some thin welding wire ,wrapped it around the end of the cable before I pulled it out and made it ALOT easier to get it back in. Made it the Chesapeake Inn by 2 to watch some football. As it turned out the guy I helped the other day lucked out also. Only pulled a rocker stud.
