Looking to raise TRS drives on a Formula 302LS
I'd really like to know more about that set up. I have the identical rig (minus raising the X-dimension). What was the X-dimension he started with and what was it after he raised it? What prop is he using? And how did changing the X-dimension affect getting up on plane? Any chance I could talk to your friend about it?
I know he was running a 26P Hydromotive quad IV-X rounded tip 4 blade, spinning them to around 6k RPM. His 540's were solid roller, Dart heads, made a tad over 700hp each. He had good luck with the TRS staying together on that setup. I think the key was letting the engines rev to get the load off the drives.
I made the mistake of not doing that - 540 w/ just less than 600hp spinning only 5,200... blew 5 TRS's in 5 years.
