max RPM on a engine >
max RPM on a engine
max RPM on a engine
Old 01-29-2014 | 12:47 AM
Default max RPM on a engine
hi guy s im building a 496 with my old 454 and now the big question ! what is the max rpm I should put on my engine ! I have a merctran trany with a TRS outdrive and I don't want to destroy it ! lol im gonna have around 425 hp with 525 lbs of torque my screw is 14 inch by 23 of pitch ( 14 im not sure cause I have try to mesure it with my tape ;s) so if I want 5300 rpm WOT what rpm I should put with the engine free ? thank you guy and hope you are able to read that thread ! im speaking French so ... a little bit hard to explain my point clearly ! lo, have a nice day !
core59 is offline
Old 01-31-2014 | 06:11 PM
Ayuh,.... Yer doin' Ok with the french to english, except for this,..??
"so if I want 5300 rpm WOT what rpm I should put with the engine free ?'
What do ya mean, "put with the engine free ?"
I donno how tolerant the Trs' are to rpms,...
A factory balance motor, is cam'ed to 'bout 4800 rpms,...
If yer motor is gonna be a Machine Shop, fully balanced motor, 5300 rpms might be safe enough,...
Anyways,... the combination of the induction, cam, 'n exhaust have to be matched to each other,...
If ya want 5300 rpms to be yer sweet spot,...
Build the motor to do that,...
Bondo is offline
Old 01-31-2014 | 11:31 PM
Rookie's Avatar
I spun my 600HP 454's to 6500RPM in front of my TRS. If your HP peak is @ 5300RPM I'd think 5500 rev limiter would be sufficient. If that's what you are asking?
Rookie is offline
Old 02-04-2014 | 04:03 PM
but what kind of trany you have between ? cause if i could push my engine at 6500 rpm without breaking all in the back its sure i would !!!! lol
core59 is offline
Old 02-04-2014 | 04:20 PM
I think the added rpm helps the TRS live longer. Smaller pitch prop and keeping the engine from peak torque area takes the load off them. And the trannys will take more torque with RPM too.
MILD THUNDER is offline
Old 02-04-2014 | 04:29 PM
here's a hint: it will ALL break at some point!
Griswald is offline
Old 02-04-2014 | 08:16 PM
Rookie's Avatar
At 425Hp you will be out of your usable powerband @6500RPM. So there is no sense in spinning your engines to 6500RPM. My original engines started life a Merc 420's and I believe peak power was around 5200RPM. My 600HP 454's made peak power at 6500 and I propped accordingly. With my new cams they make less HP but, carry more torque. They now make peak power around 5800RPM so I have propped up to only pull 5800RPM. Funny thing is my boat still runs 79mph both setups, cruise is better now.
Rookie is offline
Old 02-04-2014 | 09:07 PM
Which is a win!
Do you miss the music from 6500RPM though?
Old 02-04-2014 | 09:29 PM
Rookie's Avatar
6500RPM in the race boat sounded great!
But, my first ever built BBC's @ 6500RPM that I assembled myself scare the s#it out of me... Yeah, they did sound awesome!
Rookie is offline
Old 02-05-2014 | 07:45 AM
425hp, pour un 496, c vraiment pas beaucoup...
pqjack is offline
