Parts needed for transom plate R&R/gimble ring repair
Originally posted this under boating on a budget. No helpful responses. Thought I may have better luck here.
Got one of my transom plates off. Need to start ordering parts. Here's what I have so far. What else??
Upper swivel pin
Upper swivel pin nut
Upper swivel washers large/small
Upper swivel bushing large
Upper swivel bushing small
Upper swivel pin seal
Lower swivel bushing/cotter pin
U-joint bellows
U-joint bellows retaining ring
tool to install U-joint bellows retaining ring
Exh bellows
Shifter cable bellows
Water hose
Water hose inserts
Water hose insert installation tool
Outdrive oil line int/ext and clamps
Transom seal
Transom seal sealant???
Thru transom bolts/studs
Outdrive seal kit
Hinge pin (pulled threads out)
Helicoil kit for hinge pin threads (5/8-18)
5/8" drill bit
Bushing install tool (Merc# 91-43578)
Lower exh pipe gasket (capts choice installed)
Bellows installation tool
Lower shift cable?
Continuity kit (ground straps, screws,etc)
Paint for bell housing and gimble ring
Trim sender screws
Hinge pin bushings
I already have :
red loc-tite
bellows adhesive
spline grease
Upper swivel pin
U-joint bellows
Exh bellows
Water hose
Water hose inserts
Transom seal
Outdrive seal kit
5/8" drill bit
Lower shift cable?
Trim sender screws
Hinge pin bushings
I already have :
red loc-tite
bellows adhesive
spline grease
you forgot the twelve pack, torch, 24 pack, anda hammer so when you get pizzed off you can beat the hell out of something. jr marine has a kit i think with seals, pin, etc.
Got a couple of torches and a 12-pack. That should get me started.
I had the gimble ring cleaned-up, boxed and ready to ship. Called JR Marine to confirm the shipping info and got the message that they are closed till mid March.I may have to wait for them to re-open to get my gimble ring fixed, but with the weather being nice, I would like to proceed with what I can do while awaiting the gimbles.
