Can i convert an Bravo One to an X Modell?
Based on my personal experience. Life of Bravo 1X behind 525: 7 hours (upper gears broke). XR upper: 3 seasons before the input shaft bearing pre-load nut loosened and took out the upper. Second XR upper with bearing pre-load hard shimmed: going on second season. Bravo 1 & 1X both use the spiral gears which are not as strong. I believe they are only cut that way to reduce noise. Both of my XRs were (are) old style which some people say had stronger upper gears than the swept back uppers.
2 straightback XR uppers spit teeth (one of the two would never hold so I think the case was tweaked)
1 sweptback XR spit teeth
1 sweptback X spit teeth
Now, I have a an XR straightback on the boat that has 40 hours and metal on the magnet. I have a sweptback X at the shop that has teeth that are looking pretty pitted but it got me home. I also have 2 used X sweptbacks that are in great shape that are my next candidates for Amsoil 140 severe gear. They are my next victims.
My latest theory is to buy used and beat the crap out of it...
I am going to take a picture of my XR junkyard for you: (keep in mind, I have stellings boxes so there is no damper and I am at 640 HP in an 8500lb boat)
