Bravo 1 Lower swap ? >
Old 05-13-2014 | 01:14 AM
Originally Posted by 502 Magnum
Ok,so now we are sure the gear difference are in the upper gear,so its no use to change the lower.
What pitch to use with my 1,36 drive when I used a 26 Bravo with my 1,50 drive ? Can I make it with a 24 P ?
Thanks.
Going from a 1.50 to a 1.36 is usually about 3" of pitch difference. You will need a 22 or 24 Bravo depending where your rpms were with the 26 and 1.50.
Yo want your rpms as close to 5200 as possible to make the most power on a 500efi. A custom labbed 24 would probably work best.
Griff is offline
Old 05-13-2014 | 03:47 PM
Thanks Griff,I do not fansy a new 1,50 drive for this boat now so I`ll try with a 24,its a pretty light 27 Rib boat,I got the motor out now for a light 400 hours service with new valvesprings and head gaskets,I did inspect the botom and I`m suprised,no wear to talk aboat on the bearings and pistons was clean with fresh springs,nice motors.
Bjorn.
I got the original old head gaskets,but I used the new style "steel gasket" on a procharger motor I got,what is your opinion around this new gaskets?
502 Magnum is offline
