Std bravo to HP gimbal assembly >
Old 06-14-2014 | 02:08 AM
Default Std bravo to HP gimbal assembly
Currently converting my std bravo transom assembly over to a very low hour, basically new HP gimbal assembly. It's a recent model as it features the 4 set screws per side and has a factory electronic trim module. Here is where I'm lost. My original trim senders have a total of 4 wires(2 for each trim sender). New unit is a 3 wire with weatherpack style connector. Has anyone done this conversion? Here is a picture of the new connector. HP unit came off of a fountain.
Borgie is offline
Old 06-15-2014 | 09:17 AM
The new style trim sender will not work with old style non smartcraft gauges. I researched this and you need the Smartcraft electronics to get it to work. You are going to have to use a mechanical gauge. Jeff Wurl
jwurl is offline
Old 06-15-2014 | 09:30 AM
Beau, you can get a digital indicator from livorsi, plug and play. Not cheap as I've priced it for my drives and tabs.
RAPTOR1 is offline
Old 06-15-2014 | 12:17 PM
Mbam's Avatar
Offshoreonly Advertiser
Actually there is a module to convert to analog signal. Pn 884359T1
Mbam is offline
Old 06-15-2014 | 02:02 PM
Really appreciate the help!
Borgie is offline
