Help Added wrong type gear lube
I was out in the shop tinkering with the boat and noticed the bottle of gear lube I had poured in the reservoirs is marked 75 hp or less.
It's been in there for 2 weeks, but I've only run the engs on the hose in the driveway.
Went to the Quicksilver website and it said not to mix it with 90w high perf gear lube.
I can pull the reservoirs off and drain them but I'm afraid some of the lube got into the drive.
Should I drain the drives overnight and install 90w high perf, or do I need to do more?
These are early Bravo 1's with 500 hp in front of them.
Thx!
Thx!
If the reservoirs were more than 1/4 full when you topped them off, then just dump the reservoirs and refill with HiPerf.
A little mixing shouldn't be critical, but with 500hp in a standard B1, you are running them on the edge anyhow and need all the crossed fingers you can get.
One of the reservoirs (port) was brand new, so it was dry. I pulled both of them and flushed them out with solvent.
Draining the drives overnight.I did notice while draining the port drive, there was a small amount of foam in the oil in the drain pan. The starboard drive had none.
In regards to the port drive, thinking abt filling and running it for abt an hr, then drain overnight again.
