Can you start your engine with a Bravo Xr in gear?
Thanks for the reply , and I have heard that also, that is the kind of info. I'm looking for, so I'm trying to pick the lesser of the 2 evils here...
Everything is for sale @ a certain $$
900rpms is no problem. When you start getting around 1000rpms,then it gets hard on the cone clutch.
You can easily wire in some bullet connectors and a switch.
I know most of shifting happens while docking. You won't be able shift the Bravos like a crash box with the engines off.
what if you just put a thumb button kill switch on the throttle or shift lever? just a lil touch when shifting. then wire the kill switch thru another shutoff so you can't inadvertently kill motor when running.
Mod done, just spliced out the safety N. sw. I'll check it out tomorrow and see how it goes. Thanks for all the ideas guys, I just wanted to keep it a KISS apporach.
Thanks,
Dean
Thanks,
Dean
