Probably an Titon oil cooler pump. Also Drew Marine has or had a set up for cooling the oil drive oil most likely the same idea or set up. it also runs thru an spin on oil filter to trap wear metals.
Originally Posted by BUP
(Post 4158558)
Artic, I totally understand and do not blame you for what is working staying with it. Just looking for someone who tear ups drives to see if this oil will be an improvement. A little info. The gear
oil is formulated from a blender who has been in business since the 70's. It is a pure Ester base with a very stout extreme pressure additive package added. Also they tell me it will still hold up well with 20 to 25 % water intrusion. Most only test up to 10 % to maybe 15% of water contamination. They say it was tested at those 20 to 25 % water levels. Also they tell me improvements to eliminating the pitting that takes place on the gear surfaces using their gear oil . I am going to test it and see if it will decrease gear oil temps and send samples off to be oil analyzed. Also I know you did or still Cryo and Rem finish your internals of your drive. I will pass this along. Controlled Thermal Processing does a good job and IMO their pricing is good for Cryogenics. Rick does a great job and has good info. 847-651-5511. |
No not either one of these. I knew if anyone would say who it would be - you would have thought of Motul. It is not. I am saying this in a good way because I know you know about this stuff.
Before trying to sell it and or private labeling, I want to see how it holds up and performs. Also I might really sell it as a private label so will not say as of yet. Its not Maxima or Torco or Klotz either. A personal friend of mine does oil analysis for living and in years past before Nascar had their own in house, he had a few of their contracts. He knows oils and I want to try what he is recommending on marine gear oil formulas. |
(Post 4158578)
http://www.ebay.com/itm/New-12v-Diff...-/280782675244 |
Originally Posted by Black Baja
(Post 4158572)
Smitty, what are you using for a pump to circulate the oil? Are you just pulling it out of the upper, filtering, cooling and returning?
Originally Posted by mike tkach
(Post 4158548)
i totally agree,royal purp is junk and i use amsoil in almost everything i own.
Originally Posted by Keith Atlanta
(Post 4158430)
What kind of clearances/backlash are you running on the upper gears (Tight side or Loose side of Merc specs)?
Do you drive the boat like you stole it or like a little girl? |
Originally Posted by payuppsucker
(Post 4158420)
Hey Smitty, if you don't mind saying how much have you got tied up in your modified drive and how long have you had that HP in front of it?
Smitty, I for one and I'm sure many others would love to see some pics of your set up. Very ingenious, by the way. Got to be fun smoking people with no idea what you're running.
7 Attachment(s)
Originally Posted by buck35
(Post 4158791)
