setting up a bravo for driveshafts >
Old 08-03-2014 | 06:11 PM
Default setting up a bravo for driveshafts
I need to move my engines forward in my 31 offshore and want to use driveshafts. Anyone have any input on this and anyone have the parts i need?
27roadster is offline
Old 08-03-2014 | 09:32 PM
How far you talkin? Just curious, why do you need to move them forward?
picklenjim is offline
Old 08-03-2014 | 09:44 PM
6" to a foot the new blowers hit the back plus the new header muffler combo needs extra room.
Old 08-04-2014 | 07:12 AM
Below is diagram for a v-6 but the driveshaft set up is the same,I will have one complete set up for sale from my fountain shortly.
Where are you located and what is the boat?
http://www.mercurymarine.com/media/m.../864695A-1.pdf
Flyin-Bryan is offline
Old 08-04-2014 | 07:44 PM
My 36 cat is set up with XRs on drivlines. Driveshafts are about 2' long though. I dont know if you can go much less??? I love the set up though!
Cobra100+ is offline
Old 08-04-2014 | 08:35 PM
I'm sure i can't move them that far we only have about two feet to the back of the seat. We may have to go to plan B?
Old 08-04-2014 | 09:59 PM
You CAN have a driveshaft cut down to any length.
Old 08-04-2014 | 10:13 PM
Its really gonna come down to how much room i have vs how much i need and what will be the most cost effective way to get this done? If i can find the driveline parts for the right price that will probly be the way to go? I have also been toying with the idea of making spacer plates for the bell and drive plate?
Old 08-05-2014 | 05:56 AM
Mbam's Avatar
Offshoreonly Advertiser
The shortest drive shaft you can get is about 10", so then you have to add the length of the 2 adapters. I don't have the standard drawing here at home so going from memory I think that will put you about 14" forward. However the parts you need are not inexpensive.
Another possibility would be to put the u joint from an ITS on the drive. That would give you about 6" forward for much less work and expense.
Mbam is offline
Old 08-05-2014 | 08:14 AM
Ayuh,.... Howdy, I'm lookin' for the motor end of that assembly, from the flywheel cover to the drive shaft,....
I've got the flywheel cover, the transom end, 'n the drive shaft,....
pm me, 'n let's see if We can make a deal,.....
Bondo is offline
