alpha 1 drive shaft broke >
Old 08-04-2014 | 08:56 PM
Default alpha 1 drive shaft broke
On vacation few weeks ago I broke the vertical driveshaft in my alpha 1. It broke about the top inch off the splines and not in the groove. My ? I guess is why it broke there? I bought a clever prop for it and changed the upper cap that goes on top the upper part of the drive. I gained a few mpg with the prop and was running it harder than normal. I got more power than I should with the alpha. I'm wandering if the prop broke it or maybe the cap on the upper was not adjusted right??
So2fast5u is offline
Old 08-04-2014 | 09:20 PM
you said you have more power,maybe the extra power killed the shaft.what do you estimate your hp to be?
mike tkach is offline
Old 08-04-2014 | 09:44 PM
375 or so. Same boat with a 330 hp big block will run about 3 mph less than I get. I know there is more to it then that.
Old 08-04-2014 | 10:18 PM
SB
What boat ? Approx weight ?
What gear ratio ? What pitch ?
What cid is motor ?
SB is offline
Old 08-04-2014 | 10:24 PM
Baja 1988 235 force. I have no idea on weight. 1.50 gear 15" by 19 pitch prop. Had a 14 1/4 by 20 on it before. I was just cruising along about 3200 rpm and it went to 5000 and the boat stopped. I also got some air on some big waves the day before but I did not have it wide open when I come back to the water! !
Old 08-04-2014 | 10:26 PM
SB
What cid ?
How old is the drive ?
SB is offline
Old 08-05-2014 | 05:57 AM
really makes no diff what broke it. shaft is done. quickest fix is another drive from craigslist. 235 Baja is heavy for a 23 foot boat. 375 is a lot of power for an alpha. real question might be..."why did it hold up so long?"
dereknkathy is offline
Old 08-05-2014 | 06:30 AM
355 Ci and it's the original shaft from 1988. I do baby it alot trying to not brake anything. I'm hoping to swap to bravo this winter so I can upgrade my engine. I plan to buy a new shaft and just repair it. Friend was trying to tell me my new prop broke it but I was thinking not!
