Recently I was talking with a local boat shop owner about this. He had a couple 1970's vintage boats in the 20-25 foot range using twin SBC with alpha drives turning in the same direction. He said at worst they only exhibited a very gentle drift to one side and was nothing to worry about. I didn't ask how fast that would go but, I would imaging 50'ish or so. Granted it's only 260 horsepower per side so not much torque there. I have no experience with this just relating what I was told.
Originally Posted by Rik
(Post 4173282)
Ok, I'll bite. Why?
I mean you would not want to run two propellers with a Z drive going the same direction, you would not want to run two propellers on an Outboard the same direction so why would you want to do this with an Surface Drive? |
Originally Posted by CDShack
(Post 4173480)
Jim , you still installing those Kaamas? Good thing about them, to reverse rotation, just have to run transmissions in forward or reverse.
Originally Posted by 502ss
(Post 4173772)
I asked the question specifically about surface drives because it's what is currently on my mind but I am interested about the effects for any drive. Does it torque steer? Does it cavitate one prop? I assume there is some historical data on this?
(Post 4173810)
Just like any other drive, the boat will want to list to one side, steer dramatically better in one direction than the other, have a harder time docking and more than likely due to the combined torque of the engine and propeller, provided they are rotating the same direction, will be slower than the alternative.
What is driving the question?
Although not surface, fella I know has a 312 stinger with same rotation King Cobras because previous owner couldn't find counter rotating one. Wore his arm out pulling to one side.
(Post 4173543)
Your probably thinking about a Velvet Drive style transmission. The Kaama had no RH or LH drive so they used a Twin Disc MG502 marine gear and those I believe were full time Forward or Reverse. They are heavy and they eat about 80 hp but they are reliable.
And can you use a velvet drive thru a single engine mounted Kaama drive? I want to install a ASD6 in my 18 one of these days and occasionally see the Kaama come up for sale and they interest me also. Back in 1986 I rebuilt a 1985 Kaama edition Formula sr1 302 with Kaama 425's in it that spent a night in the surf and than another day on the bottom of the Gulf . :Long story short even after the motors had been upped to 500s after the sinking the boat did not seem very fast even with 4 bladed Rollas . Must have been the high parasitic tranny loss. I always felt it was slow because it was a heavy boat and also that there was a ton of sand left under the cockpit that could not be accessed.. Never had any experience with a surface drive before that but remember when the 1st article came out in Powerboat about the Arneson claiming 10 to 15 mph gains I think the test boat was a old 70s Pachanga? Buddy put a asd6 on my old boat and saw the 10 to 15 gain no problem |
Back when we had are old 26 foot Monza with the screaming 6 bangers in it back in 74 it strayed to the left because you couldn't hold onto the wheel hard enough because of all the feedback from the daul Rack non assist steering , That boat pulled so hard left i bet it only went right 1% of it's whole life.
6 years later when we popped a mold off it and started building the 26 with twin 260s non counter the power steering helped a bunch with torque steer . But if you had that thing riding on the props in a narrow passage like the narrows in Macatawa at full throttle you could see it was walking hard every time it got up on the props. Saw it especially one day later on when the guy who took over our molds and was building a very light /cheap lay up of the 26. Raced him with my 18 from the Heinz Factory all the way up Macatoilet against a 20 mph west wind and chop He had me by a good 5 mph but he had to keep slowing down as he was walking so bad.Boat had a ton of rocker in it and was a handful at 65 though. |
| All times are GMT -5. The time now is 10:49 PM. |
