Differnance between #4 and #5 Speedmaster >
Old 08-19-2014 | 10:01 AM
CIG3's Avatar
Default Differnance between #4 and #5 Speedmaster
What are the main differences between the #4 and #5 with big shafts. I know the original #4 had small shafts.
CIG3 is offline
Old 08-19-2014 | 08:14 PM
SFOcean's Avatar
Charter Member #394
#5 is a much shorter drive - higher propshaft height.
SFOcean is offline
Old 08-20-2014 | 06:57 AM
CIG3's Avatar
I thought #4 and #5 length was the same. #3 was the longer version
CIG3 is offline
Old 08-20-2014 | 07:01 AM
4 and 5 are the same size, roughly 6" shorter tha a 3 or 3a. The 4's have smaller bearings and gears than a 5. Upgrade are available from Gary k.
Unlimited jd is offline
Old 08-20-2014 | 07:25 AM
RMPRam's Avatar
Lil red is correct. All the #4's have a "polygon shape" front driveshaft, while some of the early #5's did also. In my opinion, the polygon shaft is just as "good" as the splined version that Mercury switched to in the later #5's. None, again from my sources, of the #4's had the near net forged, straight cut upper gear sets. They were a later "up-grade" in the #5's. The lower gear sets, RH and LH internal splines, on the #4's and the #5's are different with the #4's having fewer splines on the pinion gears, than the later #5's. A #4 can be upgraded to be, again in my opinion, as strong as a #5 with the addition of a set of the net forged, straight cut polygon'd upper gears and also the 1.75" dia. propshaft. I have both of these pieces, new, available for the #4. Check my classified ad for more information. If I can be of any help, please don't hesitate to give me a call.
Gary
612-247-7081
RMPRam is offline
Old 01-03-2015 | 04:52 PM
14 apache's Avatar
Ttt
14 apache is offline
Old 01-08-2015 | 08:43 AM
its been said... Gary K has all the parts required to upgrade a #4 to almost what a #5 would be... the only difference would be that a #5 case is a little stronger, beefier in the bearing areas...
adk61 is offline
Old 01-08-2015 | 11:06 AM
RMPRam's Avatar
Alan is correct. I have new, near net forged, not machined, polygoned upper gears in a 1.31:1 ratio and new "big" 1.75" dia. propshafts all for the #4 SSM drive. Contact me if you need parts for your #4 or other SSM drives.
Gary
612-247-7081
RMPRam is offline
Old 05-10-2016 | 10:18 PM
Veteran: Marine Corp
Veteran: Coast Guard
Veteran: Space Force
Gary can i grab an email to contact re parts for ssmiv. Im located international.
32footcat is offline
Old 05-10-2016 | 11:34 PM
I'm wondering about the power required to turn one of these drives. Would a small shaft #4 require less power (less parasitic power loss) to turn than a large shaft #5? Any thoughts?
carcrazy167 is offline
