-   -   b1 bellhousing r&r (https://www.offshoreonly.com/forums/drives-lower-units/317004-b1-bellhousing-r-r.html)
buck35 09-01-2014 07:44 PM
Thanks cole I went back through the pdf manual and its actually a merc special part #,91_78310 ,
did not mention that untill you get to the reinstall, go figure.
buck35 09-03-2014 12:07 PM
Okay, so I'm trying to figure out which part number I need while waiting for the removal tool. Merc part 41646a7 matches my transom # but 41646a9 appears the same but says with gear lube. Are they referring to the oil bottle in the engine bay?
buck35 09-03-2014 10:32 PM
Well at least the lack of responses leaves me feeling like less of an idiot. :throw::readinghelp:
buck35 09-06-2014 05:00 PM
2 Attachment(s)
[ATTACH=CONFIG]528871[/ATTACH][ATTACH=CONFIG]528872[/ATTACH]
so this is what I have found, the only # on the bellhousing is 41646c1
which one do I order 41646a7, or 41646a9 with oiler?
I can deal with nuts and bolts, but wtf, how you figure this chit out!
Davidpiscit2008 06-12-2024 05:12 PM
Did you ever figure this out I have the same part # I can't find anything please help
Davidpiscit2008 06-12-2024 05:15 PM
Or if possible message me
