-   -   Looking for he - removing Velvet drive installing Bravo (https://www.offshoreonly.com/forums/drives-lower-units/318352-looking-he-removing-velvet-drive-installing-bravo.html)
Marks69camaro 09-23-2014 09:07 PM
Installing a 454 that has a Velvet drive transmission that I am removing and changing to a Bravo drive. If I am correct I will need the flywheel, bellhousing, coupler, and starter ?? Not sure what or if I am missing something. Any input would be greatly appreciated. I would be interested if there are any parts available. The Velvet drive is available as well. Any input would be greatly appreciated - thanks in advance !!
IRONMAN 09-23-2014 10:14 PM
You do not need the flywheel, just bolt up the coupling to the one you have.
What model velvet drive, I may have some parts to trade you
Marks69camaro 09-24-2014 06:50 AM
Thanks for the help - the Velvet drive tag reads: Model 10-18-006 1.91:1 ratio
Since I can't use any of the parts from the drive I'll leave the starter, bellhousing, etc. on it if that helps
Let me know, thank you !!
hullofjustis 09-24-2014 07:06 AM
I do believe you will have to remove the ring gear and flip it over. When the starter is on the back side the ring gear is turning the opposite direction. I have a coupler possible bell housing but i am not positive about that. And a backing plate.
I did the same to my 86 scarab panther that had trs drives on. Since you have to move the engine back you may consider raising the x dimension a couple inches
Marks69camaro 09-24-2014 07:13 AM
Let me know about your parts, thank you. Question on the coupler - reading posts it appears there is a standard and a heavier duty version. Motor has a ProCharger and is making close to 600hp. Which coupler do you have ??
hullofjustis 09-24-2014 07:37 AM
I have the standard one which i have ran 800 hp behind them without any issues. Not the extra one i have though
Marks69camaro 09-24-2014 08:30 AM
Let me know about the bellhousing, etc & prices - thanks for your input !!
hullofjustis 09-26-2014 07:54 AM
1 Attachment(s)
pics of coupler
Craney 09-26-2014 05:01 PM
Don't forget you also have to move the engine back about 10'' to 12''.
dereknkathy 09-29-2014 06:30 AM
1.91 ratio. this is a shaft boat engine you picked up. NOT a TRS velvet drive. is the boat you are installing it in already a Bravo boat? did it come with any of the parts? where is the starter? down low on the engine where it goes in a car-I/O? or on top pointing towards the transom? if that case the ring gear is in the wrong place for your needs. please tell me you are not converting a shaft boat to Bravo...
