Boating Rookie Needs Advice >
Old 09-29-2014 | 04:05 PM
Default Boating Rookie Needs Advice
I've got a 2000 Baja 25 Outlaw w/ Bravo 1 (340 hrs) and got some serious slop in the drive. Real tough to maneuver around the docks. I got it out of the water for the season and found a guy I trust to help me pull the drive off. Now I have been told that it is the Gimbal Ring that needs replacing. Is that accurate? Do I need an entire new transom assembly or just the ring itself. Going to pull the motor to get at it instead of drilling. Anything else I should replace since I am getting this deep into it? Thanks for you help guys...
Outlaw252k is offline
Old 09-29-2014 | 04:16 PM
obnoxus's Avatar
Charter Member #1171
Either a new, or rebuilt gimbal ring,,,,, or add hydraulic steering
If you end up replacing the ring,,,,, get a new steer shaft ( will probably be pitted and corroded ) and steer shaft seal as well
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-29-2014 | 04:17 PM
First figure out where the slop actually is. Most likely the little tiller arm.. The upper pivot pin on the gimble ring attaches to iit. At that point wear loosen the tiller arm, sometimes you can tighten it back up with the pinch bolt, sometimes you have to replace the pivot pin and or tiller arm. If you are going to rip into it, now is a good time to replace the bellows and gimble bearing,
phragle is offline
Old 09-29-2014 | 04:37 PM
So no need for new transom assembly then. Just the ring, steer shaft and seal should do the trick?
Old 09-29-2014 | 04:39 PM
Slop is side to side (when on trailer) and pretty significant. Since motor will be out, I would like to replace anything that needs to be replaced. Don't want to have to pull again.
Old 09-29-2014 | 04:45 PM
The gimble ring itself is usually ok, its the pin and the tiller that usually take the beating.
phragle is offline
Old 09-29-2014 | 05:27 PM
If you're asking what you should do while the engine is also out, you should probably replace the bilge pump, hose and blower hoses. A nice coat of paint. Fix some
Of bajas horrendus rigging from the factory. Give the engine a nice bath and maybe a coat of paint wouldn't hurt. New belts and impeller. Add an oil drain hose to the drain pan if you don't have one installed,
depending how long you've owned the boat id put a new starter on it if it's been on there 4-5 years. (I'm a guy who ways worries about battery's and starting)
I'm sure there's more. That's just off the top of my head. Just hang around here long enough and we will love to spend your money lol.
mickeymcclgn is offline
Old 09-29-2014 | 05:43 PM
check it with the engine running
boatnt is offline
Old 09-29-2014 | 07:26 PM
VoodooRob's Avatar
Search JR Marine, their aftermarket replacement parts are engineered better than stock. Used them on a past boat to repair bad ring, pin, and u-bolt.
VoodooRob is offline
Old 09-29-2014 | 08:35 PM
The upper swivel pin nuts are supposed to be retorqued every so often, to take up any slack from wear/stretching. Nobody ever does that, and it turns into a slop fest in there. I had a bravo boat years ago, that had some play there. I loosened, and retorqued the nuts to spec, and it really took out alot of the play.
MILD THUNDER is offline
