Cons to surface drive? >
Old 10-10-2014 | 06:20 AM
Originally Posted by hallj
Hi there, I have a single Arneson.
Trim it down and the water goes under the boat and it's not an issue.
Jeff
How do you like having the single surface and what boat is it on? Length? And power?
greenmonster383 is offline
Old 10-10-2014 | 09:21 AM
Jolley's Avatar
Darr win????????
Jolley is offline
Old 10-10-2014 | 03:04 PM
can you get bow lift from a surface drive?
pstorti is offline
Old 10-13-2014 | 12:41 PM
You can't force the bow up like with a regular stern drive, but they do trim out and gets lift, etc. You can feel the boat raise and lower in the water at speed, it's just not a pointed nose up sort of thing. Basically it's just like a regular boat, nail the throttles, let it get going and max out RPM, trim up until you hear a props lose a little bite, bump down until you hear it grab, and that's your base trim setting. Weight and load distribution is adjusted off that trim setting.
CDShack is offline
Old 10-14-2014 | 06:03 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
If bow lift is needed, just like in the cases with a Mercury drive, you can use a propeller with more rake if needed.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 10-14-2014 | 06:29 PM
I am considering Arnesons for my next boat and was wondering if staggered would be better to give the drives better leverage, or side by side to keep the weight back? As far as the drives sticking out, I was planning on a custom aluminum swim platform to cover them.
ThisIsLivin is offline
Old 10-14-2014 | 07:05 PM
Rik's Avatar
Rik
Depends.. Honestly if your not going over 100 mph I can see little benefit for most boaters to have a stagger setup..
What are you going to build.
Rik is offline
Old 10-15-2014 | 06:41 AM
So far I enjoy it. 20' Donzi. Just upgraded to a 445hp small block. I've had it for quite a few years.
Jeff
hallj is offline
Old 10-15-2014 | 06:51 AM
Jeff
What speeds are you getting out of that combination.?
tommymonza is offline
Old 10-15-2014 | 07:00 AM
Not sure yet. I have only run it with the new engine once and it was very brief.
I'll have to wait until next summer.
Jeff
hallj is offline
