Cons to surface drive? >
Old 10-15-2014 | 07:01 AM
  #31
I'm looking at a 39 or 41 Velocity with 1600hp minimum, so definitely over 100.
ThisIsLivin is offline
Old 10-15-2014 | 12:00 PM
  #32
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Then a stagger setup on this application would be a good thing.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 11-24-2014 | 02:22 AM
  #33
Anyone running a 25' or 27' with a single surface drive? If you post a photo of the engine compartment that would be awesome. Looking for a visual of the layout from behind the motor to the transom.
greenmonster383 is offline
Old 11-24-2014 | 08:04 PM
  #34
Rik's Avatar
Rik
looking for? The engine placement will depend upon which drive you are referring to and so on.
Rik is offline
Old 11-24-2014 | 11:52 PM
  #35
Rik do you have any install photos of ASD6 in a single configuration in 25 V-hull or Cat?
Old 11-25-2014 | 12:57 AM
  #36
Rik's Avatar
Rik
Yes, we have everything from a 22' Eliminator to a 25' Talon, 26 AO, a 26' Firehawk (all the same boat essentially) a 25' Carrera and so on..
Rik is offline
