Please help 1990 Bravo1 upper gear needed >
Old 11-03-2014 | 01:38 PM
Default Please help 1990 Bravo1 upper gear needed
Top gear in upper drive gear set clutch ring separated.
Looking for upper gear only or affordable set.
1.36 ratio. Any suggestions on who to contact for this part?
I'm aware they are now only supplying the newer style with retrofit kit.
I'm trying not to spend $1000 if poss.
Any leads are appreciated Thanks!
DGOODMAN808 is offline
Old 11-04-2014 | 09:01 AM
Mr Gadgets's Avatar
Charter Member #601
I may have a spare one in the shop. Send me a pm as a reminder, please, and I will take a look and see if I have a lone gear.
Dick
Mr Gadgets is offline
Old 11-04-2014 | 10:30 AM
Call John at the Bravo Shop. He has lots of good used gears.
Also there was a 1.36 gear set in the Swap Shop within the last few months.
Griff is offline
Old 11-04-2014 | 11:48 AM
Pm 242ls. I took his drive apart last week and he has 1 gear that is ok. I don't recommend mixing and matching gears but I guess it will get you by
Unlimited jd is offline
Old 11-05-2014 | 10:22 AM
Mr Gadgets's Avatar
Charter Member #601
I have a used complete upper set, 1.36. Pinion and fwd gear look good. Rev looks like new.
Old 11-05-2014 | 10:46 AM
Thanks for the leads!
