Water hose in transom assembly. >
Old 12-28-2014 | 07:05 PM
Default Water hose in transom assembly.
I bought a good used transom assembly for my 242. When I installed it, I noticed the water hose seems loose at the gimbal housing. I do not want to disassemble the transom assembly. I bought the insert tool and inserts on ebay tonight. Will I be able to locate the hose on the transom plate and install the tapered fitting from the inside of the boat?
79formula is offline
Old 12-29-2014 | 06:59 AM
Ayuh,.... Ya oughta be able too,.... Is the motor still outa the hull,..??
Bondo is offline
Old 12-29-2014 | 07:57 AM
seafordguy's Avatar
Yes you can get to it assuming the motors not in yet
seafordguy is offline
Old 12-29-2014 | 04:59 PM
Motor is out. Inspected it today. The area on the gimbal housing had a little bit of corrosion. I didn't want to have it fail later on so I ordered an aftermarket repair kit.
http://amarket.com/BRAVOBLOCK.HTM
Old 12-29-2014 | 07:10 PM
Just an FYI. Mercury came out with a fix for the intake hose where it goes thru transom assy. The replacement hose now comes as a kit with a plastic pipe where it passes thru transom. All new transom assby. Have this new hose with tube.
Clustergear is offline
Old 12-30-2014 | 05:58 AM
Clustergear ..I'm not familiar with the new merc part you listed. Do you have part number .Last hose I got certainly wasn't a kit ...It was a hose
motor is offline
Old 12-30-2014 | 08:40 PM
I was putting in a new transom aassby. About a mount ago and there was a plastic thing sticking out were inside water neck bolts on. Something didn't look right so I called Merc Tech support they said there should have been a bulletin in the box about new hose. I had parts guy pull water hose that were in stock and found new ones that have plastic tube. I am not sure of part number as shop is closed for holidays so I don't want to give wrong part number. I do have a copy of the instruction for the new Bravo water hose Kit assby. its four pages if you send a PM with your e mail I can take pictures with my iPad and send to you
Old 12-31-2014 | 12:02 PM
BUP
Mercruiser has not update the parts schematics for the newest parts nor the part #'s to show on the parts search. IMO they still might have the water inlet male quick connect available possible in x amount quantities that need to sell first. Just a guess at this point.
BUP is offline
Old 12-31-2014 | 04:04 PM
Good to know they came up with a fix. I googled it and couldn't find anything .any links or #'s .
motor is offline
Old 12-31-2014 | 04:45 PM
BUP
Attempted fix at the moment not really having that much tested service time as of yet. And like I said you not find anything currently about it as IMO the older parts need to get off the shelf beforehand. I still have 5 in stock so I could just image what the numbers really are elsewhere including at Merc..
BUP is offline
