Trim tab indicator cable length 37 Stiletto anyone know the length?
What 43v said. Measure a rope and attach it to the old cable and pull it out then you will know exactly. Then when you get the new one attach the rope to it and pull it back through. Works well with my Nautiques, not so well with my old DCB that had everything cushion clamped and wire tied front to back. Had to nearly take every bit of the interior out, etc to change it.
Usually the part number is printed on the jacket right near the end of the cable. If it is not easy to access under the dash to see, loosen the cable retainer fitting on the tab, and you can probably pull enough cable jacket out from the trim tab side to see.
