-   -   Bravo 1 gimbal replacement stock or ss? (https://www.offshoreonly.com/forums/drives-lower-units/322584-bravo-1-gimbal-replacement-stock-ss.html)
motor 02-02-2015 06:55 AM
Since the engine is out ,do yourself a favor and pull out the transom assembly for the repair. The only reason I can see for doing the cobbling fix (JR) is for someone without the ability to remove engine .Once the engine is out if transom has good cut ,it can be done without removing transom assembly .....But why not install new transom seal while you are this far.....meaning, pull the assembly ..Do it once do it right ....M.O.
Originally Posted by Dmac88sport226 (Post 4258379)
I was just curious about taking the inner transom plate off so I don't have to put a hole and a plate on the outer plate to get the gimble ring out. Pismo, I heard there was some fit problems and I know for some of them you need external steering.
CIG3 02-02-2015 02:15 PM
The JR Marine stuff is nice. Also makes it nice to be able to check for maintenance.
