Alpha 1 serial #
Old 02-20-2015 | 05:49 AM
Default Alpha 1 serial #
I went to my boat in its hiding place before spring and was going to get serial number off of drive to identify which one I have to order (2) of everything impellers, u joint bellows etc etc etc. The plate right below the greese fitting for gimbal bearing that says Serial# is blank and or cant see anything. Its as clean as day but no #'s or anything. On either drive. Is there another location? Is the serial number that is on valve cover of engine the right thing? Kinda confused boat is a 1986 Wellcraft Nova 2 260hp twins. Any advice of another location would be great.
86Nova2 is offline
Old 02-20-2015 | 06:18 AM
Then maybe once I get rhat figured out someone can guide me to get correct part numbers for all new stuff for this years season?
86Nova2 is offline
Old 02-20-2015 | 06:35 AM
Mbam's Avatar
Offshoreonly Advertiser
The drive serial number is on the port (left) side on the upper housing. It should be stamped into the housing even if someone has put a new decal over it.
In any case the is a Gen 1 Alpha, you can find parts for it here http://www.mercruiserparts.com/selec...?doc_nbr=99964
There are actually 2 flavors, and I see that there are 2 u joints depending on serial so you really should locate it. If you post the numbers on the valve cover I will take a look in Mercury and see if I can find it that way for you.
Mbam is offline
Old 02-21-2015 | 06:13 AM
Ayuh,.... There are internal clips, 'n external clip u-joints,....
I'd recommend ya tear it down 1st, just to see what parts are Needed, 'n what parts are still serviceable,...
Bondo is offline
Old 02-23-2015 | 10:18 AM
BUP
Your app is an Alpha 1 - Gen 1
it would be wise to buy a transom repair kit for your app - it is cheaper this way than buying each part. I have anything you need for this including the transom repair kit, all brand new of course.
BUP is offline
Old 04-08-2015 | 04:45 PM
Serial number on valve cover is B409833 I can'find anything on the drive at all....
86Nova2 is offline
