Looking for used Arneson #7 conversion drives >
Old 03-12-2015 | 12:04 PM
Originally Posted by 502ss
As already stated Mike has a 30' scarab S-Type with early Arnesons where the engines are actually backwards in the boat and driving the Arneson with a v drive setup. They are indeed Arnesons and not Kaama's!
That is correct, kind of an odd ball set up. Didn't you posted a pic. of the set up, with v-drive and shafts under the engines. Snow is melting, thank goodness, see you in April.
I'CE is offline
Old 03-12-2015 | 01:06 PM
Thank you to those that have inquired about buying the Bmax drives that would be replaced if I can find the right Arneson setup. The assemblies, extension boxes, drives, cat tie bar, etc... with less than 20 hours on them would likely all be for sale if I can source the right Arnies. I probably should not get any hopes up before I know that it will work out though. I hope to be in contact with you soon if that is the case.
croaker is offline
Old 03-12-2015 | 02:00 PM
Yes, just clearing things up for Phil as he was mistaken!
502ss is offline
Old 05-29-2017 | 06:27 AM
I have a single asd7 that I may want to sell
zemaestro is offline
Old 06-03-2017 | 01:56 PM
Default Arneson drives, Huber trans, powe rsteering pump, HD u joints
I have a pair for sale, still on the boat, u can test drive it. new in 2010, 1.58 gear/ resealed in 2012 , new chain side (insurance paid 10k) in nov 2016 all done by Rik. Complete setup 18x30 4 blade props. cell 717-554-9967
Inrecovery is offline
Old 06-04-2017 | 05:52 PM
What power and boat do you have them on?
Cary 29 is offline
Old 06-04-2017 | 05:57 PM
540 tall deck, 38.2 fastech twin step
Old 06-04-2017 | 06:32 PM
about how much do you want for them?
sutphen 30 is offline
Old 06-04-2017 | 06:39 PM
30 k takes the whole package, I also have the spanner tool, extra seals, 1.36 gear ratio, extra HD driveshaft, extra hyrdo lines. And its still on the boat, on the lift ready to go. flywheel to the prop and the upgraded power steering pump.
Old 06-04-2017 | 08:13 PM
jeff32's Avatar
can you post a picture of your boat? Not too many around with arneson and i almost bought an arneson 382 from typhoon performance couple years ago with my 357 on trade! Just curious if it is the same boat!
jeff32 is offline
