-   -   TRS drive parts/help! (https://www.offshoreonly.com/forums/drives-lower-units/324711-trs-drive-parts-help.html)
picklenjim 07-23-2017 01:13 AM
Engine has to be removed.
apmechanic99 07-23-2017 07:38 AM
Yeah that's what I thought, manual isn't to clear on that, thanks picklenjim.
cig28 07-28-2017 08:35 AM
I have 2 brand new mechanical shift conversions if anyone is interested, 2 brand new gimble rings that were mercurys last design with the u-bolt, big and small block drive plates, lower drive case and a box of pilot bushing that goes in the crank for the output shaft support of the merc trans, these are a must when using a merc trans. The bushing need to be turned down on a lathe for proper fitment. Also a couple of transmission that will need to be rebuilt before installation.
Thriller62 08-08-2017 04:28 PM
I need the pilot bushing for the crank shaft, are these still available?
SutphenL30 08-22-2017 03:30 PM
I've got them in stock. P/N: 23-71647. Offshore Performance Specialties Don Carter 239-489-0884
[email protected] 10-12-2018 12:08 PM
Complete trs drive
I have a complete trs center drive from a 55’ scarab triple engine setup from the engine flywheel to the prop nuts bolts plates the whole work s
