SCX Upper gear setup >
Old 05-10-2015 | 05:02 PM
Tinkerer's Avatar
At this point the plan is to have a blow through carb. BUT it just might end up injected because I would use a front mono throttle body.
Tinkerer is offline
Old 05-10-2015 | 06:30 PM
Originally Posted by Tinkerer
I will make over 1400 HP on 93 octane with the M4 on my 598 CI BBC.
I absolutely loved my fuel injected prochargers! I love all forms of forced induction when done correctly though.
The question is will your engines actually support 1400hp? How "use able" will this setup be especially with a blow thru carb?
Not singling out any one person but making reliable marine power is not as easy as OSO thinks. Its one thing to make a dyno number another to have it last in offshore conditions for 100s of hours.
SCX and SCX-4 are only rated for about 800hp, yes they do OK behind more power but.....
And the SCX-4 swinging an offshore style clever prop is no walk in the park to dial in, plus dont forget to upgrade helmet, gimbal ring, reservoir, and adding an extension box.
offshorexcursion is offline
Old 05-10-2015 | 07:08 PM
Tinkerer's Avatar
Already have the extension box ( going on this spring) and the boat came with an HP gimbal assembly and oversize reservoir. And dialing in a boat is what I have done many times. Before I even thought of adding HP.
Have you heard of DAVE WESSELDYKE - He is the person doing all of the machine work ( I will assemble the engine - Not my first high HP engine or my first solid roller ) I am using all of the parts to handle the power I plan on producing.
This is all going in a light boat that will run at high RPM with a very high X dimension so there is NO chance of hammering on them out of the hole. My X last year was 1 inch above the lowest part of the hull. With the new neutral extension box I am going up another inch and may even go a little higher. Last year I ran a -3 IMCO shorty ( 11% slip from 4000 up to 6000 RPM) but have a -2 as a spare if needed. SO IF I go lets say to 2 1/2 inches above and it is too high I can just install the -2. I adjusted the drive for more negative trim in order to get on plane. ( It didn't begin to get on plane without this mod.) adding the box should make the increased negative trim work even better and with the higher X I should be able to trim the drive in more for more efficiency. Last year I was playing with props. Had the 28 pitch Bravo one off of the Scarab and was getting on plane without any real problem ( -3 ) Then chopped 1/2 inch off of the flare on the back of the prop to try to settle the transom at top speed. ( it worked great but was a SOB to get on plane.) The boat loved not having the bell on the prop acting like a ski. I also sealed the cavitation plate to the drive and sealed the exhaust passage through the drive to stop air getting into the inside of the prop while getting on plane. I figure the water sitting inside the upper drive housing wouldn't hurt the cooling either.
Dart big M tall deck block, Crower crank, Lunati rods and JE pistons. AFR 355 CNC heads with upgraded valves and springs ), Bob Madera solid roller cam and his recommended lifters with internal oiling. 14 Qt oil pan, Jessel belt drive and Jessel pro shaft rockers. I am thinking at this time to use a Holley HP EFI as the ignition control and latter adding the fuel side.
Tinkerer is offline
Old 05-11-2015 | 07:52 AM
Kick ass engine.
Cole2534 is offline
Old 05-11-2015 | 07:51 PM
Tinkerer's Avatar
Tinkerer is offline
Old 05-12-2015 | 04:44 PM
DesertRage's Avatar
Not even close to the info I was looking for guys...
DesertRage is offline
Old 05-12-2015 | 04:57 PM
No problem, glad we could help you out.
endeavor1 is offline
Old 05-12-2015 | 05:01 PM
DesertRage's Avatar
Not the help I was looking for.
Old 05-12-2015 | 06:05 PM
Again, no need to thank us.
909-592-6162
https://www.imcomarine.com/cal_store/
Old 05-12-2015 | 06:45 PM
Anyone have any experience setting up SCX upper gear lash? I'm curious what numbers you may have seen. I'm going through one now that had a lower shed some metal. The upper is in great shape but I'm still doing a tear down to flush and check where the lash was originally set. This is a low hour drive so I don't think it would have changed much.
Thanks,
Jon
The upper pinion gear back lash should be .006" to .008"
Send me your email and I'll send you more spec's on setting up the upper
oceanoutlaw is offline
