Bellow Glue
Old 06-10-2015 | 09:27 PM
Default Bellow Glue
I need to replace my driveshaft bellow on my drive and was reading that you are suppose to use bellow glue when installing the bellow. After further reading I found that some people only use it as a precaution to make sure that the bellow doesn't come off when reinstalling the drive. While others say that it will be okay without the glue as long as you make sure it doesn't get bumped off when installing and make sure that the clamps are on tight.
Do I need to get the glue for the bellow or will I be okay if I just make sure that it is clamped on tight and there is no gaps?
EMTJEEP is offline
Old 06-10-2015 | 09:49 PM
Last time I did the shifter bellow I used the glue...it's scary enough knowing that a $5 piece of rubber keeps your boat floating.
1MOSES1 is offline
Old 06-10-2015 | 09:57 PM
BUP
it is way more important to make sure the flange you are installing the bellows on is 100 % perfectly clean and no peeling paint. Also a quality bellows is important.
BUP is offline
Old 06-10-2015 | 10:25 PM
My setup has a transmission so i don't have a shift bellow. But i do wish the driveshaft bellow cost $5.
EMTJEEP is offline
Old 06-10-2015 | 10:26 PM
I'll see if the boat store has the bellow glue tomorrow and if they don't just make sure everything is clean and goes on smoothly and check it as soon as I get the boat in the water.
EMTJEEP is offline
Old 06-10-2015 | 10:35 PM
I think the bellow kit is roughly $100 but it probably costs merc $5 to make...that was my point.
1MOSES1 is offline
Old 06-10-2015 | 10:45 PM
FYI..use real bellows, not the cheap ebay crap..... they are NOT the same. I have had a cheapo fail in LESS than a season.
phragle is offline
Old 06-10-2015 | 10:48 PM
The bellow I got from my boat store cost about $110. And I wouldn't trust buying online for parts like that especially since my drive is very outdated and hard to find parts.
EMTJEEP is offline
Old 06-11-2015 | 02:34 AM
You can use 3M Weather strip adhesive which is available at auto parts stores. Pretty much the same thing.
picklenjim is offline
Old 06-11-2015 | 03:19 AM
+1..ate my words....same thing the merc stuff is a little darker..
FIXX is offline
