-3 imco
Old 06-15-2015 | 06:12 PM
Default -3 imco
Can a -3 Imco be installed on a bravo1? Does it require modification to bolt up? If so, what needs to be done?
01scarab29 is offline
Old 06-15-2015 | 07:13 PM
Yes it can but you need to modify the rear of the upper or you will be limited on prop diameter
MDGperformance is offline
Old 06-15-2015 | 07:19 PM
The cavitation plate will need to be notched/stepped so the prop has clearance
oceanoutlaw is offline
Old 06-15-2015 | 07:24 PM
Tinkerer's Avatar
It will clear a stock Bravo 4 blade prop. All You have to do is install the cavitation plate that comes with the lower and cut off what hangs below it. About 1/2 inch. I used a sawzall with a 12 inch metal cutting blade using the bottom of the cav plate as a guide. That is what I did to mine. I am running it on my Daytona.
Tinkerer is offline
Old 06-15-2015 | 08:06 PM
Do you have pics to better help me see it?
Old 06-17-2015 | 02:31 PM
bor's Avatar
bor
This is a complete imco -3" drive as you see there is a step in the cavatation plate .
its for sale by the way
bor is offline
Old 06-17-2015 | 04:15 PM
I wish. Why are you selling
dsmawd350 is offline
Old 06-18-2015 | 12:14 PM
bor's Avatar
bor
I have a 21 v hull whit 560 hp ls that I m converting to normal 5.0 mpi bravo to make it affordable to sell as I m building a new cat for speed whit twins ,going to use the ls for that and have 2 new xr s for the cat
used the imco for 15 hrs I bought it from the owner of revolution marine that used it on his personal boat for 30 hrs then he switched to scx-4
bor is offline
Old 06-24-2015 | 03:54 PM
Picture ?
Old 06-24-2015 | 07:53 PM
Tinkerer's Avatar
If you only plan on using a Bravo prop than you can just bolt on the cavitation plate that comes with the lower and cut off what hangs down below it. This is how mine looks.
[ATTACH=CONFIG]542441[/ATTACH]
Tinkerer is offline
