Bravo xr failure? Why?
I really recommend talking to George at All American Drive Service. I just had their Stage II done on my drive. They have improved a number of major weaknesses in the current drive. My bearings gave out and caused a strain on my top shaft which broke causing some significant destruction. They have redesigned the bearings and shaft for greater strength and gave me a 2 year warranty for 650hp.
It probably isnt the drive so much as it is the stellings box. Can you insert a drive alignment tool smoothly before inserting the drive or do you have to loosen the bearing carrier bolts?
I shimmed my bearing carrier so once tight, the drive alignment tool slid in like butter. That eliminated some of the failures. Still dont know how to reduce harmonics, but I am open to suggestions. One thing I will swear by is the Max Machine Works Top Cap with 7/16 studs - I think that made one of the biggest differences in rigidity and allowed slightly higher torque on the top cap bolts.
Anybody else have something int he drive line to reduce harmonics?
I also had my drive shafts balanced.
Does it help ??....I really can't say, but I haven't blown any sh!t up in a while
It helps, but there is no getting around the fact that its steel to steel. I have researched carbon fiber shafts but the people who build them said its too short to offer any real benefit.
Merc make a set up that is not steel on steel with a small input shat to a bravo coupler then a drive shaft it works !!! I don't know how to post the pix of the parts off the merc web site if someone can do it I will be happy to talk to them over the phone 401-841-5866 bill
After driving a boat with regular XR's and jumping in a boat with XR behind Stellings you can hear it when you put it in gear. Even at low RPM it will have a metal to metal "ping" when you engage forward or reverse.
Not to mention what running high horsepower with a lopey cam through no wake zones. I am confident it hammers the gears to death.
