XR Lower Gear Set Question? >
Old 07-09-2015 | 09:43 PM
Default XR Lower Gear Set Question?
I have a standard length Imco lower that I purchased used many years ago. It has a 1 1/4 shaft and a blue bearing carrier. I don't believe Imco's came with a blue carrier, so I believe it was rebuilt at some point, and am not sure if any thing else has been changed.
I need to put in a new lower gear set soon, and am not sure what part number I need. I see many different part numbers for a 1.5 ratio,15/19 gear set. How do I know which one I need ?, Should I take it apart first and see what part numbers are on the gears? What differences do I need to know about.
Thanks,
Steve
Revd Up is offline
Old 07-09-2015 | 11:03 PM
Is it from an IMCO SC Drive
253 is offline
Old 07-10-2015 | 06:50 AM
Yes it is a SC lower. I am not sure if the prop shaft and bearing carrier are Imco though.
Revd Up is offline
Old 07-10-2015 | 07:27 AM
Pull it and inspect carrier shaft seals ect .who knows , might have some tbs gears in there
airjunky is offline
Old 07-10-2015 | 07:34 AM
All XR uppers have 16/19 gears. You change ratio in the lowers ie. 15/19 = 1.5 ratio; 15/17= 1.36 ratio; 17/18= 1.26 ratio.
Bawana is offline
Old 07-10-2015 | 07:37 AM
Oh, the part # for the merc lowers gears to get 1.5 ratio is 43-818928A2
Bawana is offline
Old 07-10-2015 | 09:27 AM
I just finished rebuilding an IMCO SC Drive for my customer, it had XR Gears , 1;5 ratio, Bawana listed the part numbers above.
253 is offline
Old 07-11-2015 | 08:45 AM
I always heard the 1:50 gears were stronger than the 1:36 gears due to the gear cut, is there any truth to that.
J.P. is offline
Old 07-11-2015 | 05:00 PM
nope
Bawana is offline
Old 07-14-2015 | 08:41 AM
Mr Gadgets's Avatar
Charter Member #601
Revd Up,
If your lower has the Merc propshaft you will need to use the XR gear set, (43-818928A2).
If it has the Imco propshaft you can use the B1 lower gear set (43-14063A1) or the XR gear set. The difference is the size of the machined hole in the driven gear. Imco sells a spacer that slides on their propshaft to take up the space on the XR driven gear.
Hope that helps.
Dick
Mr Gadgets is offline
