Amsoil 90-140 Oil  Results >
Old 08-03-2015 | 10:52 PM
I scattered my early model bravo x drive in my 03 25ol with 290 hrs and replaced it with a 2015 bravo x with the fluted cap should I run the 75-90 or the 75-140 its time to change the oil in her and I have the 75-90 in the shop. Advantages , disadvantages I would like educated opinions that was a expensive deal because when it chunked up it took out my coupler. Thank mike
sunbather1969 is offline
Old 08-06-2015 | 12:27 AM
I picked up some REDLINE heavy shockproof this time around. Film thickness greater than an SAE 75W250, yet low fluid friction like 75W90 what they claim.
Stuff looks like strawberry shortcake mix, till you smell it. Hate gear oil smell.
ICDEDPPL is offline
Old 08-06-2015 | 06:30 PM
The Red Line Heavy is GOOOOOOD SH---t! Ive seen it come out of 6.58 Gear behind 850hp on Asphalt for 500 miles and not even turn color! Temp was in the 375-400 Range.
The NEO products are also Excellent. Amsoils MLM sales model turns me off , they have decent stuff , but I think their Technologies are behind alittle.
dunnitagain is offline
Old 08-06-2015 | 07:00 PM
Originally Posted by zgoo
A friend bought a low hour Eliminator with a 496ho and X drive with 50 hours, first day out he ran it at about 4,000 rpm for a short while and when he got to the dock he noticed the drive was really hot. I had some Amsoil 75-140 Severe Duty Gear Oil and we replaced the clean stock oil in the drive with the Amsoil, The next day we went on a 20 minute run at 35-4000 run and stop and the drive was hardly even warm!! He and I were pleased with the results. Also when draining the stock oil it flowed out very slow as always, but when filling the with Amsoil and it was time to replace the drain plug after pulling the fill line, the Amsoil shot out of the fill hole at a rate of five times as fast as the stock Merc oil, very slippery stuff!!
Might have to try that stuff...good info!
Diamond Dave is offline
Old 08-07-2015 | 04:46 PM
As was stated earlier the 75-140 will slow you down slightly, I run the 75-110 as it was recommended by the Amsoil tech I talked to. On another note, George from AADS has noticed that recent batches of extreme gear are creating havoc with the cone clutch. He has had several new rebuilds go bad very quickly. He changed the oil to Merc Hi-performance and swapped the clutch and no problems. He is working with Amsoil to figure out what they changed that is causing the problem. He just rebuilt my drive and I am running the Merc oil to break it in and then I will switch to NEO.
ThisIsLivin is offline
Old 08-10-2015 | 03:37 PM
That's interesting and seems to line up with my experience. I have not had a problem since I switched back to Merc hi performance lube.
ALL_IN! is offline
Old 08-10-2015 | 04:16 PM
articfriends's Avatar
let us know your results, one of them i heard foamed up pretty bad , not sure which one seems like that info came from Teauge?
articfriends is offline
Old 08-11-2015 | 07:47 AM
Knot 4 Me's Avatar
No cone clutch problems running this:
Knot 4 Me is offline
Old 08-14-2015 | 01:50 PM
I didn't have a problem with Amsoil Marine Gear Lube, but I heard it wasn't as good as severe gear. So I switched to Severe Gear, and that's when the problems started. Switched back to Merc and all is good (I hope!).
I've had the boat for 3 seasons and haven't been in the drives yet - that is on the to-do list for this winter. it's probably over due.
ALL_IN! is offline
Old 08-14-2015 | 02:34 PM
Knot 4 Me's Avatar
Yeah we're not running the Amsoil Marine in anything over 500 HP.
