Steps to adjust Stellings Standoff Boxes >
Old 09-01-2015 | 09:37 PM
My propshaft height using a straight edge to the front of the nosecone on my bravo std lowers comes in at 4.5 inches below the running surface. I rarely have more than 2 people in the boat and minimal gear. Even when I tested 27p mirage 3 blades the boat came on plane fine without using tabs so I think we're ok in that respect. I'd like to get the bow up some more, but if we move to -2 shorties will it hurt or help this?
Joe308 is offline
Old 09-01-2015 | 10:19 PM
Our experience is if you can get on plane with 3 blades at 4.5" BTB you will be able to get on plane at -2.5" BTB but you likely/may have to go to the Bravo 1 props. If you hit the sweet spot/combination, it could give you +4-5 MPH. The worst case is you sell the -2 lowers and Bravo 1 props if you don't like the result. You could also likely borrow Bravo 1 props for testing. Keep us posted on your project.
BenPerfected is offline
Old 09-02-2015 | 06:44 AM
I have bravo 28s and 30s and they bite better but the 4 blades drive the bow down. What effect does raising the prop shafts 2' have on stern lift?
Joe308 is offline
Old 09-02-2015 | 12:48 PM
Going to -2 shorties will give less bow lift with less leverage to lift it.
If anything, I would have the props labbed to reduce stern lift and increase bow lift.
Griff is online now
Old 09-02-2015 | 02:45 PM
Thanks Griff, I've been talking to BBlades but we need to test some more with the 30s before settling on a plan for a prop mod. If I do the shorties after the props we might end up with expensive paperweights so its a coin toss now. Anyone have 2 shorty lowers they can lend me?
Joe308 is offline
