TRS weak cases?
Old 08-14-2015 | 09:17 PM
VoodooRob's Avatar
This might sound crazy but could the cases be tweaked and fatigued from failures and hours of running?
VoodooRob is offline
Old 08-14-2015 | 09:29 PM
Full Force's Avatar
Thaysbwhatbi am thinking, or just a set of gears let go that just happens too I guess
Full Force is offline
Old 08-14-2015 | 10:13 PM
Craney's Avatar
What gear oil do you run in them?
Craney is offline
Old 08-15-2015 | 06:22 AM
Full Force's Avatar
I have ran valvoline 80w90 for years.
Old 08-15-2015 | 07:45 PM
Originally Posted by redcorvetteman3
What is the weakest part of the drive? I can't remember anymore..
for me it was the lowers vertical shaft,,I'd snap those things like nothing and in turn would window the lower case.
sutphen 30 is offline
Old 08-15-2015 | 07:48 PM
how are the lower gears dying?Can you post a pic.almost sounds like a set up problem but then after that,something could be moving in the case to lose the back lash and bearing preload.
Old 08-16-2015 | 01:21 AM
Arneson and never look back.
tommymonza is offline
Old 08-16-2015 | 06:34 AM
Full Force's Avatar
Didn't take it apart yet but it's not setup, my buddy knows these drives been doing them for years never had issues, really thinking its a case issue but could just be bad luck too
Old 08-16-2015 | 11:23 PM
text me a pic of the last set of gears..i would like to see the contact pattern..
FIXX is offline
Old 08-17-2015 | 04:39 AM
Full Force's Avatar
by feeling it there will not be one like the last set that totally exploded.....
