-   -   Hard to get on plane-NXTs (https://www.offshoreonly.com/forums/drives-lower-units/330214-hard-get-plane-nxts.html)
Mad Props 08-28-2015 02:43 PM
I have a 35' V with side by side NXT's my hole shot is horrible. I maybe over propped a little but on a lake I get full RPM range. NXT's have built in vents so I am wondering if additional vents or covering existing vents would help. I over speed engines frequently and have tried every drive and tab combo and multiple drive heights and in and out with props. Anyone with similar experience?
Thanks for any help. P.S. always enjoy reading these forums
hullofjustis 08-28-2015 03:46 PM
Hard to get on plane as the props blow out or it lumbers and the bow stays in the air forever?
Griff 09-01-2015 01:41 AM
Sounds like you need to do some prop testing. Call BBlades.
47 lightning 09-01-2015 07:34 AM
what props are you running bravo style or # 6 mercury or hering.
Mad Props 09-03-2015 09:15 PM
The boat feels like there is no props so I guess that's blow out. Bow up feathering to keep off rev limiters. The props are six drive clevers 37" 17 dia 19 rake.
47 lightning 09-04-2015 09:07 AM
spinning in or out ?
Mad Props 09-07-2015 05:56 PM
Spinning out and it is a little better spinning in but the over all handling is better out.
hullofjustis 09-08-2015 10:29 AM
you are over revving your engines? and it is hard to get on plane because the props blow out?
are you using a 4 or 5 blade prop? if you have tried drive heights try using a satin finish prop where polish finish is removed or sand the finished off the prop.
my x dimenson is too high on my boat and I actually can get on plane with my satin finish 4 blades vs my polished finished five blades.
Sydwayz 09-08-2015 10:35 AM
Are you using the tabs to get on plane?
An old raceboat trick:
Push the boat up until it just starts to blow out.
When it starts to blow out, chop the throttles back, and let the wake hit the back of the boat.
1) It will surf you up a little bit.
2) You now have a wall of water with the drives deep in such wall of water that you can apply power and and push the the boat all the way on plane.
--You won't get it right the first time. There is a timing/trial&error to it.
Mad Props 09-09-2015 03:28 PM
The props are satin finish 5 blade cleavers.
I do use tabs about half down. More makes it worse. I will try the little push method this weekend. If I can have stiff wind at my back it helps quite a bit.
I am tempted to install prop aerators I would just hate to make it possibly worse.
47 lightning 09-09-2015 03:59 PM
I have a 38 top gun with high x that I been having the same problem . turning in is better but lost 3-4 mph . now turning out. I wind it up to 4500 rpm until it reaches 20mph then I back off throttles to 3000 rpm it catches. then quickly accelerate and it gets right on plane .if its rough out I have to go with the following sea. then turn back once on plane. bravo style 6 blade herings
hullofjustis 09-10-2015 11:20 AM
Originally Posted by mad props (Post 4352910)
the props are satin finish 5 blade cleavers.
I do use tabs about half down. More makes it worse. I will try the little push method this weekend. If i can have stiff wind at my back it helps quite a bit.
I am tempted to install prop aerators i would just hate to make it possibly worse.
i don't think the aerators are going to help. I had to put a 1 inch spacer on my drives just to use the following see method. I have been able to get on plane using the satin finish 4 blades much easier than using the polished 5 blades.
Mine will not get on plane at all with the tabs down. Have you tried pulling them up?
F-2 Speedy 09-10-2015 11:48 AM
Try the tabs neutral, first time I had mine out the tabs were 1/3 down and the props would blow out, so I set them in the neutral position and it came up, nosed over like butta
Mad Props 09-14-2015 06:00 PM
I was out at the SCOPE poker run this weekend in San Diego and tried a few things recommended here and so far patience is the only thing working lol. But I did have an awesome time boating down there.
