Small Chunks On XR Drain Magnet :( >
Old 09-19-2015 | 09:59 AM
Default Small Chunks On XR Drain Magnet :(
Not concerned about the fuzz on the magnet but these chunks were also stuck to it. Drive oil otherwise looked good. Are these most likely from the upper gears? The upper magnet was clean. If I pull the back cover off the old style XR can I inspect the gears? Thanks.
thirdchildhood is offline
Old 09-19-2015 | 10:12 AM
TYPHOON's Avatar
You need to completely disassemble the WHOLE drive. Upper and lower need to be cleaned and inspected. Nothing good will happen if you just find the broken part and replace it. Its a great time to have a complete rebuild done.
TYPHOON is offline
Old 09-19-2015 | 10:14 AM
TYPHOON's Avatar
I would also suspect its your lower gears. Chunks that big would have a hard time making it to the bottom case IMO.
TYPHOON is offline
Old 09-19-2015 | 10:56 AM
Thanks. I will pull the drive and take it to my mechanic, Brian, of Orlandi Performance. Big water boating is done now anyway.
Old 09-19-2015 | 02:31 PM
I see a rebuild in you future. Small chucks make bigger ones. Then...... BOOM !!!!!! new drive time...That's how my summer ended anyway..
David H is offline
Old 09-19-2015 | 03:10 PM
Yeah, the drive is off and going to Brian Monday. He said he can get right on it.
Old 09-19-2015 | 03:29 PM
How many hours?
indysupra is offline
Old 09-19-2015 | 03:49 PM
bwd
Look at the bright side, at least it still holds oil. Usually when 1 of mine lets go it takes the case too. Always pays to check the magnets.
bwd is offline
Old 09-19-2015 | 04:11 PM
Biggus's Avatar
Agree with all above. I'm lucky to get 35 hrs out of a set of lower XR gears before the magnets start looking like a Chia Pet.. It will be good to know what's going on, I suspect your lower gears have some heavy pitting, since you don't have any debris on the upper, you might luck out and not have to replace upper gear$.. Good maintenance program (checking the magnets etc) can really save a LOT of money. -Also curious on the hours..
Biggus is offline
Old 09-19-2015 | 05:58 PM
There are 2 seasons on the upper and a whole bunch of seasons and hours on the lower. It's an Imco lower with at least 200 hours. Brian said the Imco uses the same gears as the XR lower. I thought the lowers were bulletproof. The good thing is if the damage is limited to the lower then the cost will be a lot less! I'll find out Monday. He's going to get right on it.
